Блендер
На сайте c 26.05.2019
Млечный Путь, Солнечная система, Земля
Как бы есть импортер:
https://extensions.blender.org/add-ons/io-scene-max/
Extension to import meshes, materials and texture coordinates from Autodesk 3DSMax (.max) files. Supported materials are Legacy, StandardMtl, Standard Surface, PhysicalMtl, Multi-Sub, RaytraceMtl, Shellac, V-Ray, VRay2Sided, Arch & Design, CoronaMtl including Corona HairMtl, SkinMtl, LayeredMtl and CoronaPhysicalMtl.Supported parameters are basecolor, roughness, metallic, specular, alpha and refraction. Texture support is for basecolor, roughness, specularity, transparency and normalmap.Only linked textures are supported, they have to be in the same folder or in a subfolder of the .max file. Compressed or partially compressed files are only supported if the format is .zip and 3dsMax version is not newer than 2023.
На сайте c 10.03.2017
